Displays the static rendezvous point (RP) table.
show ip pim static-rp
None
User EXEC
The show ip pim static-rp command displays the following information:
Output field |
Description |
GRPADDR |
Indicates the IP address of the multicast group. When combined with the group mask, it identifies the prefix that the local router uses to advertise itself as a static RP. |
GRPMASK |
Indicates the address mask of the multicast group. When combined with the group address, it identifies the prefix that the local router uses to advertise itself as a static RP. |
RPADDR |
Indicates the IP address of the static RP. This address must be one of the local PIM-SM enabled interfaces. |
STATUS |
Indicates the status of static RP. |
The following example displays the static RP table.
Switch:1>show ip pim static-rp
Pim Static RP Table - GlobalRouter
GRPADDR GRPMASK RPADDR STATUS
239.0.0.0 255.0.0.0 20.0.0.90 valid
